Front windows Slow.
TILTNTURN
Currently Drives:: RENAULT MEGANE MK11 2009 CC Dynamic S 1.6vvt .
Audi TT 225 Quattro .
Front windows Slow.
Postby TILTNTURN » Thu Dec 29, 2016 12:31 pm
Hi had a look to see if anyone else has this problem but cant find a post.
Both Passenger and Drivers front windows are pretty slow when raising not bad when dropping .
I assume this is not normal and a sign of wear with the motors . Has anyone got any suggestions { other than replacing motors } on improving the motion ? Thanks .
q292u
Global moderator
Currently Drives:: 2003 Clio. The Megane died.
2001 Audi A2 1.4 SE
Re: Front windows Slow.
Postby q292u » Thu Dec 29, 2016 12:38 pm
Dodgy motors, electrical fault or just needs lubrication.
Start with cheap stuff. Have a look at the motors and mechanisms. WD40 or spray grease. Check fuses & switches. Seems odd it's both windows..
ChrisM
Postby ChrisM » Tue Jan 03, 2017 1:18 pm
:no DO NOT PUT SPRAY GREASE ON THEM.
The grease.
A) attracts dirt
B) causes resistance in the window guidess = even slower windows.
Use a silcone spray by all means pop off ur door cards to do it properly chances are they are just dry but can can get lazy motors but as said start cheap
q292u
Global moderator
2001 Audi A2 1.4 SE
Postby q292u » Tue Jan 03, 2017 2:16 pm
ChrisM wrote::no DO NOT PUT SPRAY GREASE ON THEM.
The grease.
A) attracts dirt
Use a silicone spray by all means pop off ur door cards to do it properly chances are they are just dry but can can get lazy motors but as said start cheap
That's what I meant to say.. silicone spray.. honest!
ChrisM
Postby ChrisM » Wed Jan 04, 2017 6:25 pm
I've done the spray grease thing on a meg 1 coupe window didn't improve at in in fact after a few weeks started to make so really odd noises like grit on glass in the end I had to change reg
All the grit dirt n dust had stuck to the runners and mechanism. Lesson learned ... grease is not always good.
Wd40 can also make some plastics swell sprayed some on my fuel flap locking rod it made the rod swell to coin a phrase so I had to replace it.
Mmmmm lesson 2 learned!
