hi guys i have a problem with the clutch noticed clutch was slipping at 40 mph and then some days it dont slip at all . car pulls off great .
now it starting to judder as driving alone after changing gear . the car has only done 46k
so would it be the clutch needs replacing ,or is it oil getting onto the clutch plate , or some one said it could be the slave cylinder ?
any advice would be great thank you
also today mrs phoned me and said ....when she put her foot on the clutch peddle to start the car it struggled to start but if she put her foot on the brake peddle it started ok ? dont know if that helps anything
megane cc 2008 46k milage
Re: megane cc 2008 46k milage
My previous cc was remapped and had clutch slip. I didnt change the clutch plate and it still gave me 220k + miles So I wouldnt worry if I was you.
.... not a must to change in my opinion unless you cant live with it......
mrs is a carer so she does a lot of miles ..had a mechanic mate drive it today and he said he thinks its contaminated ?had a price of £300 clutch and fitting so think thats what i gotta do and go from there see if any oil seals have gone
- Currently Drives:: Megane cc 1.5 dci, megane hatchback 1.5dci
I had a 2006 1.5 dci with 90,000 on it , the clutch juddered intermittently and was very high and quite sharp when I bought it and for the 3 years I had it and the previous owner swore it had done this for the 6 years he had it, so maybe not a disaster if you can live with it
