dropped doors
sandman0705
Currently Drives:: Megane cc 1.5 dci, megane hatchback 1.5dci
dropped doors
Postby sandman0705 » Sun Jan 07, 2018 10:26 pm
Hi all, sorry if it's been said before but I will tell you my fix. The doors on the CC being big heavy buggers ,tend to wear the hinges and drop and will not line up properly. I recently bought an oldie but a goodie - 06 100.000mile diesel for silly cheapness, one of the probs was the driver door not lining up, u had to lift it to get it to shut. I jacked up door using a piece of wood to stop damage and released the top and bottom nuts off the hinges,jacked up more just enough to create a space then put 2 thick (2mm) spring washers on the bottom hinge only and tightened it all back up...and ...no one was more surprised than me that it actually bloody worked- door lines up perfectly again - so might be a quick and easy fix for someone else.
Re: dropped doors
Postby Stranger » Mon Jan 08, 2018 5:34 pm
Great stuff, thanks for the info, sure it'll be useful to some :tu
Andy1970
Currently Drives:: Renault Megane Privilege Convertible 1.6 VVT
Re: dropped doors
Postby Andy1970 » Mon Feb 12, 2018 12:28 am
On mine (04 plate) the drivers door drops a little when opening. This fix sounds like just the thing I need.
Thanks.
