Thought I'd get this out there to prevent others from a potential problem
I recently ordered and fitted new KYB front shocks, coil springs and top mounts to my 2004 1.6 megane cc. To be sure I got the correct items I first went to the on-line supplier and confirmed part numbers via reg number as usual. I then reconfirmed via KYB's on-line catalogue. Parts arrived and visually they matched the originals so I went ahead and installed them. Well after installation I wasn't happy with the front ride height but read a few owners reports that things needed time and miles to settle. I gave it a few days but perhaps only 50 miles as I was sure things weren't right. Did some detail comparison measuriing with the original which fortunately I'd kept and found the spring wire dia of the new coils to be 0.5mm greater. The result after more digging using my VIN and contact with KYB tech support turns out to be the KYB catalogue recommendation for my vehicle type is wrong.
In truth KYB have been good from a tech support perspective but I'm fighting to get a refund or replacements from the supplier who quote their returns policy that parts should be unmarked and in original packaging. I've reiterated to them that they sold me the wrong parts and the issue wasn't apparent until they were fitted. KYB state that once fitted the coils cannot be considered new saleable quality and they will reimburse the parts supplier. The supplier will happily sell me the correct replacements but why the hell should I pay twice for their mistake even if the result of a KYB shortfall
For ref the KYB PT should be RH2712 with a 12.5mm wire dia and not RH2711 as their catalogue states. However please double check yourselves.
Megan Cabrio 1.6 coil spring be careful
Re: Megan Cabrio 1.6 coil spring be careful
Update,
On return of the incorrect coils springs the supplier has accepted responsibility and will refund in full, which is good. Still have the hassle of doing the job twice though, which is annoying.
glad u got sorted.
Cheers mate,
- Currently Drives:: motor
- Currently Drives:: megane II cc 05 reg, megane II cc 07 reg megane III cc 11 reg
for future reference!!!!
Try to find a proper renault part number
http://catcar.info/renault/?lang=en&l=c ... 1OMzEwMjEw
then look up for a part number on uncle google and you will find this for a spring:
Fitting Position:
Front Axle
Spring Design:
Coil spring with constant wire diameter
Length [mm]:393
Thickness [mm]:12,50
Diameter [mm]:157
Weight [kg]:2,10
Colour Coding:
Blue, Orange
Condition:
New
Fitting Position:
Front Axle
Spring Design:
Length [mm]:393
Diameter [mm]:157
Weight [kg]:2,10
Colour Coding:
Blue, Orange
Condition:
New
