fuel filter
fuel filter
Just done a quick service on my 1.6 petrol Megane 2 but I'm blowed if I can find the fuel filter, can anyone help ?
- Currently Drives:: 3 door citrus green Megane II
Re: fuel filter
i think is hidden behind the drivers side head light opposite side to the battery
54 1.5DCI Extreme remapped,JVC Head unit, Pioneer front Kenwood Rear Amp & 10" sub
Re: fuel filter
thanks for the reply mate, I had a quick look earlier and the only thing in that area seems to be the dryer can for the air-con so I'm going to spend a bit more time tomorrow. Thanks again
- morganjake1544
Re: fuel filter
I think Grosseberger is correct. I believe it is near the washer bottle and a bugger to get at. If you remove the o/s/f wheel and take off the plastic wheel arch liner you should see it on the right as you're looking into the wheel arch.
Re: fuel filter
Hi all, I am also seaching for the fuel filter on my 1.6 16v petrol and cannot find it, it is not located behind the o/s headlight as suggested, it is on diesel cars, but NOT on petrol's anyone help with this problem, many thanks.
Re: fuel filter
It's located on the rear left side of the car under the fuel tank/next to the rear left tyre.Need to lift car up to be able to see it.
- Currently Drives:: 1.6vvt coupe, 1.9dci scenic
Re: fuel filter
i was informed that the fuel filter was built into the tank and could not be changed
- direstraits
Re: fuel filter
arse wrote:Just done a quick service on my 1.6 petrol Megane 2 but I'm blowed if I can find the fuel filter, can anyone help ?
It is integrated inside the fuel gauge in the fuel tank. Not necessary to change it.
Re: fuel filter
Just changed mine abt a month ago,but was told that it wasn't necessary too.Did it as part of my normal servicing.
Re: fuel filter
direstraits wrote:arse wrote:Just done a quick service on my 1.6 petrol Megane 2 but I'm blowed if I can find the fuel filter, can anyone help ?
R u refering to the megane II 1.6 16V?B'cos mine is located on the undercarriage next to the rear left tyre.
- direstraits
Re: fuel filter
abkt wrote:direstraits wrote:arse wrote:Just done a quick service on my 1.6 petrol Megane 2 but I'm blowed if I can find the fuel filter, can anyone help ?
There are certain models up to certain year of production that has fuel filter. Others don't. It's a Renault thing.
Re: fuel filter
ya correct....
esp FL ones.
the fuel pump has:
1. fuel strainer
2. fuel pressure regulator
3. fuel gauge sending unit
4. pump motor.
all these f(n) in one unit....strainer is the filter.
esp FL ones.
the fuel pump has:
1. fuel strainer
4. pump motor.
Re: fuel filter
I too am looking for the fuel filter on my 2007 1.6 petrol scenic, i gave the motor factors the reg and it cam back as just a metal canister type with a pipe each end, I have just been under the car and cannot find anything like it all i can see is next to the fuel tank just infront of passenger rear wheel is a funny rectangular shape plastic item with what looks like fuel pipes attached at the 1 end, any ideas ? thanks
Users browsing this forum: Google [Bot] and 18 guests
