megane GT rear bits
jim1.9dci
Currently Drives:: 53 1.9dci
megane GT rear bits
Postby jim1.9dci » Thu Mar 12, 2009 5:30 pm
where can you buy this metal plate and exhaust? would like to put 1 on my 1.9dci or even a 225 rear if its a straight swap for exhaust ,if any1 knows??
pocket
Currently Drives:: Mineral Blue Megane GT dCi 150
Re: megane GT rear bits
Postby pocket » Fri Mar 13, 2009 10:09 am
the GT plate is plastic not metal.
A dealer would be the best place to start i'd imagine. I'm not sure the plate comes seperate from the bumber though. The GT bumber hangs lower than your standard meg bumper. You'd probably need to buy the whole bumber.
there is a custom exhaust from here. http://www.k-tecracing.com/show_product.asp?id=2451
Its expensive tho', not sure how much the standard one costs from a dealer.
Mineral Blue Megane GT 2.0 dCi 150
Cabasse 4x40w with 6 disk changer, Pioneer TS-Q131C speakers, Kenwood KSC-SW10 sub.
TheFinn
Postby TheFinn » Fri Mar 13, 2009 3:31 pm
https://cgi.ebay.de/Original-Renault-Meg ... dZViewItem
Price 119 Euros plus p&p.
Can't really see any other difference than the plate between the standard and GT bumper, are you quite sure it hangs lower???
Exhaust shouldn't be a problem: have some exit pipes custom fabricated and welded to your existing backbox. There might be an extra bracket needed to support the pipes though, at least the 225 has one.
2,0 16V 6-speed manual: Image - Image
pocket
Postby pocket » Fri Mar 13, 2009 4:09 pm
thats a shocking price for what is a small bit of plastic. I'm sure the bumber hangs lower so that the exhaust passes through the holes in the bumber. I cannot for the life of me remember where i read it mind you.
jim1.9dci
Postby jim1.9dci » Sat Mar 14, 2009 6:39 pm
thanks alot , il check the dealer for a price on that bit otherwise il have to learn german lol, the bumper does not look any lower than standard but could be a few cm difference so fabricating custom exits sounds good :)
tallpaul
Postby tallpaul » Tue Mar 17, 2009 5:44 pm
i looked at this a few months ago.
the 'GT' plate is £130 from renault and the exhaust rear box starts at £140+vat from a motor factors. The only place i've EVER seen that plate for sale outside of a dealer is that european ebay auction.
the bumper is a slightly different shape at the bottom to allow extra clearance for the pipework, it also has holes where the plate clips on. i was planning on converting mine with the standard bumper and just trying my luck.
jim1.9dci
Postby jim1.9dci » Wed Mar 18, 2009 8:10 pm
yeah lookin at more pics you can tell the bumpers are slightly different so i dont think it would work out :?
phillyftw
Currently Drives:: megane 1.9 dci, remapped and lowered 35mm, 18inch momo wheels 8 inch kenwood flip out screen and 100 watt mutant sub, and ebc brakes
Postby phillyftw » Fri May 01, 2009 2:49 pm
i got the twin pipes welded onto the exhaust exit at the back of the car, then brought twin pipes thru the bumper and now just awaitin the gt plate. there is no noise but why would you want noise from a diesel all it does is make is sound shite so i decided to just go for the pipes welded onto the cat..Image
sum-megane
Postby sum-megane » Thu Jun 18, 2009 8:41 pm
hi guys,
I am also looking for GT rear bumper + twin exhaust for my renault megnae 1.5 dci dynamique 106 for a quite while now. Is there any website or place where I can buy all of them. Hopefully they will fit straight way without any modification to the car chasis????
Much appreciated.
onlyme
Currently Drives:: PUNTO MK2
Postby onlyme » Thu May 27, 2010 3:27 pm
iv just won the plastic plte from ebay £30 and £10 postage... WINNER!!
il be looking to get a twin exit fabricated for the exhorst ports early next month :)
mezo
Postby mezo » Wed Sep 09, 2015 10:50 pm
where i can buy this plastic plate ?
Postby Stranger » Fri Sep 11, 2015 2:05 pm
If you read back through the posts you'll see various places where you might be able to buy it, personally I'd start with e-bay.
