Clueless about HID's and Xenons
Markjohnstonn
Currently Drives:: 5dr 1.5 dci Megane
Re: Clueless about HID's and Xenons
Postby Markjohnstonn » Mon Jul 25, 2011 9:47 am
think ill just wait and get the HIDs when im back from the holiday then :cool:
also my chrome indicator bulbs arrived today, anyone any idea how easy these are to fit ?
Thanks, Mark
ikhan
Postby ikhan » Mon Jul 25, 2011 10:26 am
Should be just twist / turn and pull the bulb holder out for the indicators.
On a side note, where are the ballasts mounted for the HID's (I'm thinking of the restricted space in the engine bay).
Also, with the autolights, do the HID's work ok with this feature turned on as apparently some cars fitted with autolights sapp power from the ballasts during starting the engine and this causes them to flicker due to low power. There is a device available for this but I was just wondering if the Magne does ok without them?
Lastly, are we using extra relay's for the HID's (I'm using a separate relay on my other car)
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
mattyc25
Currently Drives:: megane mk2
Postby mattyc25 » Mon Jul 25, 2011 2:15 pm
not sure mate.
Ive never had a car with auto headlamps before, but i dont see why they shouldnt, none of the wiring is altered in any way, so yeh it should work.
If you take off the bumper you'll see a lot more places you can mount you ballasts. I had to do this to find a place to mount mine.
If you havent done them yet be carefull with the full beam, i ended up having to remove one of my headlights to retreive the spring clip for my bulb lol
Matt
ikhan
Postby ikhan » Mon Jul 25, 2011 3:14 pm
Hi Matt, thanks for that.
I know it makes sense to do the high beam, but I might just leave them as standard as they're not used often enough. Probably will depend on the overall cost in the end.
Has anyone used the H7C burners? I was thinking of using them. They are shorter still, but downside is the burner has a slightly shorter service life
Lowered 45mm (Spax)
Markjohnstonn
Postby Markjohnstonn » Wed Jul 27, 2011 5:57 pm
Incase anyones read this and considering getting the cheap 'xenon' bulbs i put a link up of.. dont bother!
Mines arrived today and when fitted they burned and smoked immediately and changed from the white/blue to the standard yellowish colour !
Guessing my lights'll be staying yellow for a while ! lol
mattyc25
Postby mattyc25 » Fri Jul 29, 2011 2:06 pm
See :P
You wouldn't have that problem with HID's.
Im still running the same bulbs that came with the kit, and i fitted the kit to my car 2 n a half years ago lol. Just get the Hid's, at the end of the day if you do find that your having problems with other drivers etc once theyre in, its quite simply a 10 minute job to take them out again.
Matt
Markjohnstonn
Postby Markjohnstonn » Fri Jul 29, 2011 3:25 pm
definetely going to get hids after this holiday in a few weeks :D
going to get the car lowered 30mm, passenger window fixed :banghead, HIDS !! and fit the phase 2 tail-lights soon im back :D
and thanks for the advice on the HIDs everyone :cool:
mattyc25
Postby mattyc25 » Sat Jul 30, 2011 1:19 pm
You'll have to post a pic up, give us all a look once theyre done.
Um forgot to mention you dont have to get blue/white. HID kits come from 5000k all the way to 15000k.
Closest match to factory fitted are white, and they are 6000k. My set are 12000k, hence the blue colour.
Any website which sells them all have charts anyway, so you can see what you think would suit you best.
Matt
Irishboy32
Currently Drives:: A 2008 megan
Postby Irishboy32 » Wed Nov 23, 2016 8:09 am
Hi lads I wanted to fit the hid kit to my car to only because I have the projectors now one thing has my head wrecked is the new cars I see a lot of them have hids on them and they are bright and there is no wiper washing system yet they get away with it I have seeming blue hid kits fitted into reflector housing and it looks horrible
Users browsing this forum: No registered users and 65 guests
