Hey i heard the heaters canhave a loss of power and results in 1,2&3 working and No. 4 being dead. What could this be if it happens?
Any ideas anyone please ??
Thanks Jord
HEATER PROBLEM + QUESTION
- WebCode
- Rally Driver
It will not be the motor, as the speed is controlled by the Rheostat..
Is this a Megane Hatch or Megane Scenic?
Common problem on the scenic where the rheostat and connector overheats.. Rheostat and connectors have to be replaced.. To do this the dash has to be removed.. 2.5 hour job..
On the Hatch it only takes 1 hour and is accesable from the passenger footwell..
- DJC013
- Currently Drives:: 2004 Scenic 1.9 dCi, 2001 SLK 320 Auto
Fan Rheostat
Hello Webcode, the fan on my 2004 Scenic has just started playing up. Is there a modified rheostat that i can order from Renault, and do i need a new connector as well ?? Regards Damian.
PS Could i fit the new parts myself ??
Thanks in advance.
Thanks in advance.
2004 Scenic 1.9 dCi 120 Dynamique 6 Speed Black 17" Nervasports VF1 JMRG
Visit my Flickr site ! - http://www.flickr.com/photos/28464546@N05/
- madwedge
- Currently Drives:: 2004 Renault Megane 2.0 litre 16v VVT Dynamique
Re: HEATER PROBLEM + QUESTION
Wow 6 years and no reply!!
As of yesterday my number 4 fan setting has stopped working. Is this a motor or resistor problem? I have an 2.0 litre Petrol 2004 Hatchback.
Any help or advice would be greatly appreciated.
- madwedge
Any chance of one of my questions being answered please? Seems to be a theme on this forum!
My no. 4 fan speed still doesn't work. Would replacing the Thermal Resistor fix this?
there is topics about this here in this forum...i will search it for you and put it here
here it is, i hope you guys can manage your problem and this post after 6 years have an answer lol
https://www.youtube.com/watch?v=XI2MJl8W0yE
viewtopic.php?f=2&t=19540&p=117710#p117710
viewtopic.php?f=2&t=22761
viewtopic.php?f=2&t=20652
goodluck
goodluck
- madwedge
Fantastic, above and beyond the reply I was expecting. Thank you very much.
Especially with the video link. Looks easier than I thought it would.
Cheers.
Cheers.
The heater is good and bad a the same time, if you will carelessly use the heater then you may you’re your life too and it will be dangerous. So before using any heater always read essayshark review because this will be so helpful for you.
Users browsing this forum: Google [Bot] and 38 guests
