rear abs mount
- Currently Drives:: renault megane 1.5 dci 80
rear abs mount
Annoying abs light been on for a while , however now the MOT is looming i thought it was time to investigate.
Turns out the rear ABS sensor was loose , problem is that the ABS mount has disintegrated so nothing to plug it into !
When you rest it against the ring and start it up the abs system is ok and light is off , obviously tho it just falls away when you move
and the light goes back on.
Does anyone know where i can obtain a mount , had a poke around the net and cant see any...
53plate 1.5dci megane 2
Re: rear abs mount
turns out you cant get without buying a a new axel !
So i manufactured a plastic plate and with some superstrong glue
fingers crossed , light went out - lets see how long it lasts
*like an episode of scrap-heap challenge *
Re: rear abs mount
10 miles it would seem
Re: rear abs mount
A second hand sensor from ebay, glued in place almost worked . ABS fault would register at 15mph
Turns out they are super sensitive to positioning, i had placed it too close to the centre,
Repositioned it today and after several hours of waiting for the glue to set - it seems to be
behaving correctly. Full functionality of the ABS system has been restored.
Lets hope it thats it sorted.
Re: rear abs mount
Hi Graham, I am having the same issue, did you sort yours and where and what did you type in for the mounting plate?
- Currently Drives:: 2004 Megane MKII 1.5DCi (80)
Re: rear abs mount
grahamlieb wrote:A second hand sensor from ebay, glued in place almost worked . ABS fault would register at 15mph
Nice one! Well done in getting it to work for you. If I saw this post earlier, I would recommend araldite epoxy.
- Currently Drives:: Megane 2005 2l turbo
Re: rear abs mount
Got abs problem on my Megane 2. The front abs connections to the magnetic ring is rusted away both sides. Abs light is lid none stop. Do Renault sell these ?
or should I just turn abs off by removing fuse?
Re: rear abs mount
you may be able to turn the light off, but it won't pass an mot test so needs sorting sooner or later.
Good luck
Bob.
Good luck
Bob.
Re: rear abs mount
grandadbobby wrote:Hi,
Good luck
Bob.
Fitted the car with new wishbones and noticed the corroded connections. Can the magnetic rings be bought online?
Re: rear abs mount
newmeganeowner wrote:grandadbobby wrote:Hi,
Good luck
Bob.
Looked for hours on the net with no luck surely someone sells these looks like a common problem...
Re: rear abs mount
the wires should go to the sensor not the magnetic ring.
Are you getting them mixed up. l believe the older toothed rings are now plastic magnetic ones, but just like you, l can't find anything on the net.
The Haynes manual is no help as usual. Haven't had this problem on my car so please do let us know how you go.
May be a case of contacting Renault to see what's the go.
Bob.
Bob.
Re: rear abs mount
Problem occurred after changing wishbones. The clip on the hub(magnetic ring)has corroded and will need replacing on both sides. Sellers sell the cable but not the magnetic ring for the hub.
Re: rear abs mount
Hi guys new to the forum, bumped this thread as it very relevant to my problem.
I replaced my rear discs today and the abs sensor holder has perished, im thinking of gluing it, my question is how far does the abs sensor have to be from the abs ring on the disc. Do they have to be touching?
Thanks in adv
Thanks in adv
Re: rear abs mount
Is this what everyone is looking for ? The ring on the inside face of the hub where the abs sensor fits into ? I have a photo but can't find how to upload
Phil and Liz Jackson
Lanark
Lanark
Re: rear abs mount
This might be what you need for future reference? https://etsy.me/2YzqMmf
