hi guys, just about to pick up a megane 2 on a 52 plate today, so hopefully will be on here a lot more. The centre console lights are not working, all other interior lights work apart from radio aircon ect.. any ideas where to start? which fuse to check? thanks
all of this bit...
center console lights not working
Re: center console lights not working
Is there any other forums I can ask on? This one seems a bit errm dead lol
- Stranger
- Site Admin
- Currently Drives:: BMW X1
Give it time, people have lives other than the net.
To be going on with have you looked at the FAQ section and also the sticky thread containing the manuals in the problems section? To save you a few seconds I've copied and pasted the link below which will take you directly to the manuals sticky:
viewtopic.php?f=2&t=12790
Yes, the fuses are in the above link. Here is the link to the actual document to read
https://ray-lee.co.uk/megane/dialogys/MR364MEGANE8.pdf
There are 2 fuse boxes, one in the glove compartment, and the other under the bonnet. You might need the first one.
Don't be surprised if you find out that the problem is caused by somebody fiddling with electrics when installing/removing the radio.
Hello,
New to the forum and I have experienced the same issue, trying to find the fuse number for the center console lights.
I have a 2004 1.5dci. If anyone could help that would be great?
Jamie.
Jamie.
I just bought a 2003 Megane and it had a unlit center console.
Following the youtube guide below I changed two bulbs behind the fan and temperature control and had light back in the center console.
https://www.youtube.com/watch?v=L5Zv72l ... XrfKek_Abg
Regards.
Mikael.
'03 Megane II 1.6 16v.
Regards.
Mikael.
Users browsing this forum: No registered users and 50 guests
