Hi I recently purchased the above the engine holds back until about 1200 revs it then clears and fly's the previous owners replaced all four coils (£130.00 including fitting) I've replaced the plugs old ones were all a light brown I've cleaned. Tdc /map sensor butterfly valve checked all vacuum pipes when you disconnect each Injector the engine speed drops any help would be greatly appreciated and thank you in advance for any help
on idle the engine rocks like a boat ( gearstick moving about)
Megane 1.6 16 v 2001
Users browsing this forum: No registered users and 0 guests
