wiring diagram
- Currently Drives:: renault megan dynamique 2006
wiring diagram
Hi has anyone got a wiring diagram for the air con,for megane mrk 2 2006.....Need to sort this air con problem out the engine bay fuse is fine but no power to the compressor.
Re: wiring diagram
Hi i believe the most probable answer is the Pressure Sensor this is behind the front bumper...a auto Electrican should be able to tell you....
Re: wiring diagram
Pressure Sensor does have power going to it,machanic said engine bay fuse fine but just no power going to connector.Also the fan doesnt come on.
Re: wiring diagram
the pressure switch having power to it doesn't mean it's working.
If it's only 2 wires, just connect them together see if it works, if not, test the compressor direct to the battery see if it activates.
Bob.
Bob.
Re: wiring diagram
grandadbobby wrote:Hi,
Bob.
hi bob thanks for helping ok so all i have to do is i connect a wire from battery to ac connector to see if the clutch engages.
Re: wiring diagram
Bob.
does the pressure switch have the same power source as the connector to the compressor.
Re: wiring diagram
Hi i have a wiring diagram
Re: wiring diagram
Try this hope it works
http://i1383.photobucket.com/albums/ah3 ... hvdlx.jpeg
Re: wiring diagram
scooper1000 wrote:Try this hope it works
Thanks very much
Re: wiring diagram
That wiring diagram is from the 'almost useful Haynes'
It doesn't mention the pressure switch.
The clutch will work off 12v, the pressure switch will probably be 12v (you could test even with a bulb) but l know so long as it's only 2 wires, you can join them together to bypass the switch.
Bob.
Bob.
Re: wiring diagram
Thats the only wiring diagram i have...i believe the pressure switch has 3 wires connected to it...new pressure switch only £15 on Ebay, might be worth changing that just to know it aint that...sorry cannot be more help
Re: wiring diagram
I had the same issue a while ago, and it should be the pressure switch. But dont let it fool you even if you replace the pressure switch you have to fix the code on the ECU because its already disabled and even if you replace the switch it wont work until u clear the code(reset ecu).
Re: wiring diagram
kush wrote:I had the same issue a while ago, and it should be the pressure switch. But dont let it fool you even if you replace the pressure switch you have to fix the code on the ECU because its already disabled and even if you replace the switch it wont work until u clear the code(reset ecu).
I will order a new pressure switch,would that explain the no power to compressor.?Because the machanic said fuse ok.
Re: wiring diagram
How would i reset ecu.?
Re: wiring diagram
I really appreciate all the help from you guys.............Ive tested compressor via a cable from battery and it spins so thats good,just cant figure out no power,so could i leave the cable on from battery,to bypass fuse box and hope i get cold air.What grade of cable would be best to use,currently i used AUTOMOTIVE 12V 24V 2 CORE TWIN THINWALL RED/BLACK AUTO CABLE.
Users browsing this forum: Bing [Bot], Google [Bot] and 43 guests
