FAQ
- Ray
- Site Admin
FAQ
I'm compiling a new list of FAQ questions to add.
Please feel free to add your questions here and i'll do my best to get the answers.
such as:
How do i get the spanner icon off after servicing?
how do i get the change oil sign to go away?
what bulbs do I need?
what oil filter do I need?
What oil type is recommended for my engine and example of such...
etc... keep them coming in!
such as:
- Bumpy macaroon
power radio, wipers, windows etc with out starting engine
How to power radio wipers windows etc with out starting engine:
for models without keyless start,
card in slot press start without depressing brake or clutch
would think for keyless start you will just press start button without depressing brake/clutch
Last edited by Bumpy macaroon on Fri Dec 21, 2007 10:12 pm, edited 2 times in total.
Bumpy and full of coconuts.
- Bumpy macaroon
How to lock doors without keycard or card broken
How to lock doors without keycard or card broken:
Stop engine,
ensure card is out of slot,
open door leave open,
press and hold in door lock/unlock button, you will hear click then after approx 5 seconds you will hear a louder clunk and dash display will go out,
get out of car and close door, all doors should be locked, courtesy lights will go out after a delay.
(remember to take card with you and if its not working will have to use emergency key to get back in)
Stop engine,
Last edited by Bumpy macaroon on Fri Dec 21, 2007 10:13 pm, edited 1 time in total.
- Bumpy macaroon
Doh
Ray, had a homer moment have put two topics in everthing else for your attn ref above two replies...
Bump go the brain cells
Re: FAQ
How to change the main light bulb.
Re: Dip Stick
d.jessop wrote:Any ideas how i can manually check my oil level on a 54 plate Megane. I've checked under the bonnet, but can't find a dip stick
its a front of the engine in front of the radiator/fan, right at the bottom. its tiny, but its there
Re: FAQ
HI Guys, I am new to this so I hope someone can help. I am running a 54 plate scenic and servicing costs the way they are I am going to do it myself, how do you reset the service schedule (get rid of the spanner) where is the diagnostic socket ? Also when opening the n/side front elec window it just dropped and I had to lift it and wedge it to keep it closed. Is this common and is it easy to fix, thought I would ask before I start to strip off the door panel. hope someone can help.
- Ray
- Site Admin
Re: FAQ
resetting the service indicator is (or was) in the faq. else it's in the forums if you use the search function
diagnostic socket is under the card reader.
re:window, you might need a new regulator. common prob.
- Currently Drives:: Renault Megane 1.6
Re: FAQ
Im sorry to ask such silly questions but I dont really know anything about cars, so id like a little a bit of help, even if they do seem obvious.
I currently have a Renault Megane DYNAMIQUE VVT 03 1.6. As I bought the car without a handbook :
I am just wondering what pressure should the tyres be?
How often do I put new oil in the car? What oil is best?
Is the little spanner flashing on my screen a problem?
Again I know these are silly questions but I would be very grateful for your help.
Thanks.
Thanks.
Users browsing this forum: No registered users and 42 guests
