air con problem
Discussions on the Megane II sedan
jackyKK
Currently Drives:: Renault Megane Scenic
air con problem
Postby jackyKK » Sat Mar 13, 2010 10:41 pm
my a/c doesnt stop, even if i turn off the car it keeps going and eats upp all the electricity. Is there anybody out there that has the same problem or even better, the solution?
Jack
Re: air con problem
Postby davelowe » Sat Mar 13, 2010 11:26 pm
jackyKK wrote:my a/c doesnt stop, even if i turn off the car it keeps going and eats upp all the electricity. Is there anybody out there that has the same problem or even better, the solution?
Jack
You'll have to supply a more information. The air conditioning system is driven by the engine via a belt to the compressor. Do you mean the ventilation fan stays on, or some other electrical system?
jackyKK
Re: air con problem
Postby jackyKK » Sun Mar 14, 2010 12:29 pm
the ventilation fan stays on, at full speed. no matter which way you set it on 0 or 4 doesn't matter.
Re: air con problem
Postby davelowe » Sun Mar 14, 2010 2:36 pm
It does this when you remove the keycard and lock the car?
Does the headlamp adjustment angle position work?
jackyKK
Re: air con problem
Postby jackyKK » Sun Mar 14, 2010 3:54 pm
it's a Renault Megane Scenic 1999, am I maybe at the wrong forum?
Gumby6371
Currently Drives:: Megane II 1.5 dci 86 3 door
Re: air con problem
Postby Gumby6371 » Sun Aug 02, 2015 1:25 pm
Does it stay on if you turn the enginenoff then press the stop/start button again?
Re: air con problem
Postby Stranger » Sun Aug 02, 2015 7:32 pm
Gumby6371 wrote:Does it stay on if you turn the engine off then press the stop/start button again?
This is a very old thread and I know that 1 of the contributors isn't a member here any longer, if you're after a solution for a similar problem you'll be as well starting a new thread :tu
Taidef1972
Re: air con problem
Postby Taidef1972 » Sat Aug 22, 2015 11:31 am
jackyKK wrote:the ventilation fan stays on, at full speed. no matter which way you set it on 0 or 4 doesn't matter.
It is really good to know about it. I was afraid of some points here about fan speed but now i am clear.
Return to “Megane Sedan”
