hi level brakelight
hi level brakelight
can any1 tell me how to change the brake light on a megane saloon as there is way to get into it without bending my fingers all different ways thnx
Re: hi level brakelight
I changed mine for the LED strip out of a wrecked volvo...
Looks much better.
As to how its done there is a guide liseted here...
https://hosted.hornstein.co.uk/Megane
Looks much better.
- Currently Drives:: megane 2 sedan
The link does not working , please anyone who has been changed the high-level brake light on megane 2 sedan show how i can change the bulb inside and how many are there .
Hi there all, sorry to drag this up again but can anyone shed any light on how to change/check the bulbs? I'd rather not be going into the stealers for them to charge me an hours labour if I can avoid it!
TA muchly,
Tony.
TA muchly,
Tony.
Ulrich recommends buying a strip of LED lights and bunging them in. Cost is £1 or thereabouts. Have a search on here.
- Anthony
- Rally Driver
This topic must hold the title for 'most views with fewest posts'.
davelowe wrote:Ulrich recommends buying a strip of LED lights and bunging them in. Cost is £1 or thereabouts. Have a search on here.
Thats the problem, I cant seem to find a guide on how to get to it, the book says to refer to the stealers and there's gotta be something that even I can do as a spanner monkey!!!
tonyw wrote:davelowe wrote:Ulrich recommends buying a strip of LED lights and bunging them in. Cost is £1 or thereabouts. Have a search on here.
Oops - erm forgot to read the above posts.... numpty.
I prised off the interior trim underneath the boot lid. I could then see it in all its glory (hatchback).
Maybe different on the sedan...
Its not that hard...
You buy an LED strip from ebay. (48LED)
Cut it to length. Connect + to + and - to -
Tuck the light bar back into the housing, refit and bobs your uncle.
Its not exactly a job that needs a guide...
gees your right 1000+ reads and no one has a response
- Currently Drives:: 2003 black renault megane 1.6 dynamique
mines just gone i`m gonna put an led strip in but do i get red leds or white?
- Napster
- Currently Drives:: Megane Sedan 1.5 dCI 2005
Clio III 1.5 dCI 2007 - Location: Constanta, Romania
Here's how you do it on the Sedan:
- you must press the 2 squares on the plastic that covers the light; you can try first pressing one and then pulling the plastic twords you just a bit then moving to the other; it's a bit of a hassle to press those plastics in all the way but after they go down you are done with the hard part
- next you remove the white plastic holder for the bulb
- pull out the bulb and go get a replacement; i don't know what type of bulb it is but it's similar to the w12w
Pics:
https://img203.imageshack.us/i/400pxw16wlampbrokenz.jpg
https://img340.imageshack.us/i/resize4resize.jpg
More info, including LED mods here:
https://www.reno.ro/Lampa-frana-spate-pa ... 09-s0.html
Pics:
Renault Mégane Sedan II.1 1.5dCi 82CP 2005 || 93000 km
hi regarding the hi level brake light ive prised off the interior plastic to expose the light,only to find that it doesnt have a buld but an led strip......any ideas on how to replace/check this as my mot is soon and it doesnt work....
many thanks
pj
many thanks
pj
I'm trying to change the high level brake light. Mine's all corroded inside.
Does anyone know one of the red plastic units off a hatchback will fit a sport tourer (the estate)? Not so many of the estates at the breakers...
