Simple question,
does the Megane II 2007 1.5 DCI Privilege use a mechanical locking mechanism to stay switched on full beams or is it electronically or relay-controlled?
Mine was working fine but now it won't stay on full been, I can feel the clicking notch halfway way but I'm not sure if it has an engaging mechanism or if it is otherwise controlled hence a relay or from the UCH or both.
Stalk light switch mulfunction
