keeping rear speakers and amp out
- Currently Drives:: Clio 172 replica
hey, whats the best way of doing it?
https://cgi.ebay.co.uk/Line-Output-Conne ... 3a540dda1f
by buying something like that, would i just have to tap into each speaker wire
or is there a more "sophisticated" way of doing it?
thanks
brocky
thanks
brocky
- Currently Drives:: 2008 Megane Cabriolet 1.9 Dci
Re: keeping rear speakers and amp out
best not to go cutting wires.....
you can get an iso adapter to go on the end of that, so it plugs straight into your radios speaker loom
like this
http://cgi.ebay.co.uk/CAR-STEREO-MALE-ISO-POWER-SPEAKER-WIRING-CONNECTORS-NEW-/370424092713?pt=UK_Cars_Parts_Vehicles_Terminals_Cabling_ET&hash=item563eff1829
like this
rbocky, Has your car got rear speakers?
Silly question, assume it has due to the title, what's your amp? I think the above is probably the most professional way to do it, I have to admit tho every car I've ever put a sub/amp in I've spliced the feed of the rear speakers wires, just seems most straght forward to me!Lol
ok so that gadget will let me keep all my current speakers, plus the amp out with another adaptor
id just have to cut the original connections for the rear speakers and crimp them into place?
rbrocky wrote:ok so that gadget will let me keep all my current speakers, plus the amp out with another adaptor
basically yes. but if you crimp the iso connector on, you wont have to cut wires now, meaning you wont need to crimp the old ones back in place when you change the sytem
This is how I had my setup in my ST500......
looks good
but slightly confused!
come again!
come again!
Basically
The original stereo loom has two parts, one for speakers, one for power etc...
you can use a female iso socket from your speaker output on the stereo, to connect to the amp
then use a male iso socket to connect to the cars speaker input from the amp, so its kind of like inserting your amp in the existing wiring, without cutting anything
by doing this, you have a plug and play system you can use with any car, and its totally reversible.
i kinda get ya, but without any pics it makes it a little difficult!
so use that ebay link to plug directly into the car stereo
then attatch a female iso to the other speaker O/Ps,
then plug the cars existing loom into this?
if im right
any links to a female iso socket ideal for use
ta mate
if im right
ta mate
could buy an iso extension lead
http://cgi.ebay.co.uk/Male-ISO-Female-ISO-Lead-Cable-Wiring-Harness-CT20UV01-/400163737947?pt=UK_Cars_Parts_Vehicles_Terminals_Cabling_ET&hash=item5d2b9e115b
That way it comes with male and female, so your cutting into this ones wiring, instead of the original loom. makes sense for the sake of a few £
the side coming from the stereo will connect to amp input, the side that connects to the cars loom would connect to the amps out put
was i kinda right the first time though
and with that, id just tap into that instead of funking up the existing loom :P yeh?!
sorry, just wana get this right!
yep
also saves you running new wires to each individual speakers as your amp output will go into the original speaker loom
The Alpine F1 status amps, come with the plug and play wiring already, which is where I got the idea
ok, so tap this
into this
https://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
then plug the corresponding ends into the stereo and the existing loom
job done?
into this
job done?
rbrocky wrote:ok, so tap this
into this
job done?
cut this in half:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400163737947&ssPageName=STRK:MEWAX:IT
Connect one end to the headunit output, then connect this (V) into it.
http://cgi.ebay.co.uk/Line-Output-Connector-Speaker-RCA-Female-PC1-601-/250518297119?pt=LH_DefaultDomain_3&hash=item3a540dda1f
run speaker outputs from your amp as normal, but run them to behind your stereo, put the left over end of this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400163737947&ssPageName=STRK:MEWAX:IT to it, and then plug that in where the stereo was originally plugged in.
job done
so its:
STEREO - Speaker Output - (Female ISO - RCA Connector - RCA Lead - Amp - Speaker Lead - Male ISO )- Original Speaker Loom
the part in brackets is the work you do if you delete the part in the brackets, your straight back to standard.
sweet mate
