AAARRRRHHHH which CD player ??
dave208
Currently Drives:: Megane expression 1.6VVT
Postby dave208 » Tue Mar 02, 2010 4:22 pm
Can someone PLEASE PLEASE PLEASE help....
I have just had a CD player delivered which is listed as for a Megane 2003 onwards upto 2008 !
But its not the same connections as my car.... Which CD do i need ???
Mine has 3 plugs, a black big one, a clear/white plastic one (Again big) and a small yellow one........
HELP please before i go mad..... Thanks
Ray
Re: AAARRRRHHHH which CD player ??
Postby Ray » Tue Mar 02, 2010 7:27 pm
assuming it's not a standard cd player (i.e. non-renault) then perhaps you need an adapter from halfords or a similar type of place.
aron225
Currently Drives:: megane 2 ph 1 RS 225
Postby aron225 » Tue Mar 02, 2010 7:50 pm
fit the 2 biggest..
the smal yellow is for steeringwheel controll, or cd changer,
you probably see this:
forget about the blue&green one.. wich you probably don't have (there's 1 for cdchanger / 1for steeringwheel/ 1 for acces0ry)
just forget the 3 blocks..
connect the 2 bigger connector's on to the new radio.. and it should play.. otherwise, there are 2 with a "banana" connector's.. just switch then round.
dave208
Postby dave208 » Tue Mar 02, 2010 11:04 pm
Can someone tell me how to post a pic, as it may be easier if i post a pic of the CD and the wires I have available
Thanks for the help so far :)
Users browsing this forum: Bing [Bot] and 11 guests
