My car audio..
My car audio..
Ok so you may have seen various posts of mine about fitting various bits of ICE, here i thought id put everything together and show it all.
Here are my door speakers, they are 6.5" Fli speakers, were going to be vibe ones but my 2 year old daughter got to them!!lol
They are fitted in custom door pods which are finnished in a blac immitation alcantara material. oh and as you can see the glove box stillopens, i have seen this done before where the glovebox will no longer open!
In the rear i have put the speakers in the parcel shelf along with 2 vibe vents.. the speakers are vibe slick and are again 6.5"
In the boot is this littl beauty, small but mighty!! its a 12" vibe 'liteair' active sub.
There is also a Fli 800 amp. (and some mess)
Here is the headunit and control for the sub amp, the headunit is the original and it works fine for me.
you can also see i have an ipod connection there.
Now ive shown you mine, show me yours!!! and let me know what you think!
- downsyndromedhorse
Re: My car audio..
Loving the door pods Joe! Well done mate, cracking job. Tempted to do mine now!
Re: My car audio..
Cheers mate, quite abits changed since then, I made a platform to go in the boot.. I'll pop some photos up when I get chance..
Have you seen the sort of step by step I did for the pods??
Re: My car audio..
Yeah had a read through most of your posts on it, looks fairly simple.
Might give it a whirl in a few weeks and see what i can do.
Got other issues with the car so this can wait haha.
Re: My car audio..
Made an enclosure for the amp the other day, here are some pics..
What do you think?- appart from that the wires need tidying up!
Re: My car audio..
Ok so been out for a bit of a drive, stopped, thought because I was going to fast but actually because lights were dimming, policeman even sat in my car with the music up so I could see for myself!lol
Anyhow I think this means I need a power cap.. Any advice??
- Eddy90
- Currently Drives:: Megane CC 1.9 dCI
Re: My car audio..
Hello mate,
I used to see my headlights dimming when i was parked up and the audio on, so i decided to add a power cap and it works for me.
Yeah i defiantly think you should add a power cap to you install.
here's my thread : http://www.meganeownersclub.co.uk/forum/viewtopic.php?f=12&t=18444
Edd
Edd
Re: My car audio..
I already had a battery upgrade, should have probably said that.. Lol
I'll have a look into power caps now then, cheaper than getting another battery!
Re: My car audio..
joeishmather wrote:Cheers mate, quite abits changed since then, I made a platform to go in the boot.. I'll pop some photos up when I get chance..
Hi mate,
would you mind posting the link to that post of yours.
Thank you!
Regards,
hyperionus
- neil_lindo
- Currently Drives:: 2005 Renault Megane II
Re: My car audio..
Here is my setup or should i say creation
Apple Ipod Touch 64gb
Alpine IVA-D310 head unit
Alpine KCA-620M USB adapter
AudioControl Epicenter
JL Audio 13.5 W7 in Custom Box
JL Audio 1000/1 v2 Amp
2 JL Audio 300/4 v2 Amps
Pair of Polk 6 1/2 db6251's - Front Doors
Pair of Polk 6 1/2 db6501's - Rear Sides
Pair of Polk 5 1/4 MMC525’s - Rear Shelf
Pair of Polk 6x9 MMC690’s - Rear Shelf
4 Boxes (36 sq ft each) of Dynamat Xtream
Tsunami 20 Farad Capacitor
XSPower D3400 Battery
Excessive Amperage 200 Amp Alternator
Monster/Stinger Power Cable
Monster Audio Cables
Custom Front Speaker Door Pods
Custom fiberglass speaker shelf
Stereo pics are on page 2 and 4.
https://www.cardomain.com/ride/2338180/2 ... ne/page-2/
https://www.cardomain.com/ride/2338180/2 ... ne/page-4/
Hope you like.
Hope you like.
Re: My car audio..
Did you really need that powercap when you have a good xs upfront and 200a alternator. I bet that jl w7 sounds nice.
- neil_lindo
Re: My car audio..
My plan is to remove the cap and add 2 xspower d680 in my trunk. The cap was one of the first things I bought so it kind of just stayed in the entire time. I was using my stock battery for the longest time. I think if I remove the cap right now I’m going to have too much draw for the 1 battery and 200amp alternator. Right now with the alternator/battery and cap I can still drop below 12v just from the draw from the 3 amps. I'm sure I can give the W7 more but I still don’t have the power to give it that extra bit. I'm hoping the 2 extra batteries will provide that little bit more to maybe play for a short while. Obviously this is at deafening levels already so daily driving is not an issue it’s only for demos and car shows.
Re: My car audio..
Ive got 210amp alternator stock front battery and d3100 in wheel well and my voltage dont drop below 13v with a 3k mono amp and 800rms 4 channel. What size power cable you running
