Hi there,
Recently bought a F1 and want to put a dump valve on it. I dont no what one to get. Any advice on whats best for the car? Cheers.
Dump Valve for Megane F1
Re: Dump Valve for Megane F1
Have a surch through. It has been well documented. There is even a fitting guide.
Regards
Regards
buy the forge kit..
it come's with everything you need..
if you open the bonnet, you'll see the air hose, on the bottom right corner..
just get that of..
replace it with the forge hose, you mount the forge valve itself ON that new pipe..
2 hoseclamp's..
now disconnect the diverter valve vacuum hose.
put a T piece on..
run a new vacuum line from the t piece, to the top of the forge valve,
an a new vacuum hose from the T piece you've just placed, and the main line..
now enjoy the whoosj..
if that isn't loud enough..
you just simply undo the 3 screw's on the diverter valve (it's bolt onto the turbo)
then replace that diverter valve, with a blanking plate wich will be in the forge kit..
disconnect the T piece,
throw away the vacuum line's
run 1 acuum hose, from the main line, to the forge valve..
i could even do it!! so you can for sure!
if you want, i can make some detailed picture's, i got it wired in the first example (so i stil get 50% recirculated, and 50% wich will blow off)
just get that of..
2 hoseclamp's..
put a T piece on..
