I hope I can post this here.
It is a strange request but is there any way of being able to disable the boot open thing so I can start the car and move it with the boot open. It will make driving feed buckets to the horses fields way easier by not having to shut the boot
the car in question is a 04 megane 1.9dci privilege (if the spec is even relevant)
boot open.
- Rally Driver
Re: boot open.
I have a1.9dci and I am able to start and drive the car with the boot open , the only thing that happens is the display on the dash shows that the boot is open ,have you tried opening the boot after you start the car
Re: boot open.
I can open it after the cars started but not start when open mines keyless (push button) I'm not sure if that changes anything. just its easy to wack in feed buckets jump in and drive up to the horses field
(used to having a pick up you see.....the boots a pain)
- Rally Driver
Re: boot open.
Mine is a 1.9dci convertable with the key card and pushbutton start on a 2006 reg don't know if that makes a differance
- morganjake1544
Re: boot open.
I think you just put the card in the slot.
Re: boot open.
Key card must be in the slot
Steve
Steve
Users browsing this forum: Bing [Bot] and 64 guests
