Hello everyone,
I'd be really grateful if someone can help me with this. I'm having a problem with my RenaultSport Megane II 225. There is an annoying vibration when the engine is idling which gets better when revs are applied but never really disappears - for example when driving along the view in the rear mirrors occasionally blurs because of the vibration even though it is less severe.I've had a garage look at the engine mounts and they say that when they bar the rear bush it goes down quite a lot but it is still present, and that there is very little play in any of the mounts, so they don't recommend changing them. They have no idea what else to suggest.
Does anyone have any ideas what I can look at next?
Thanks for any suggestions!
megane 225 vibration, not engine mounts?
Re: megane 225 vibration, not engine mounts?
I'm having the exact same problem at the moment mate. Do you find it more difficult to pull off in 1st unless you give it a few revs first?
Check the exhaust as I've been told the bracket behind the rear bumper is knackered so needs replacing and that's probably causing it apparently, will know more this week. If I find the solution before hand I will post it here.
Paul.
Paul.
- Currently Drives:: Renault Megane Sport 225 Cup
Sorry to say i've got the same problem and trust me it's not the exhaust braclets as i've replaced them already.
Next on my list was my engine mounts, but as you have indicated that this may not be the course them alais im am also banging head against a brick wall.
There is no movement on idle on the rev counter and when the car is stationary the vibrations stop?????? On starting the car the engine sounds like its hunting ie virbrates then stops then virbrates again. Apart from this there are no warning lights/ no loss in power and the car in a joy. Somebody must know what the problem is???
Answers on a postcard.
Thanks Funky.
Thanks Funky.
- Currently Drives:: Renaultsport225 Megane Trophy.
I have the same problem, however mine only occurred after the engine had be moved to change the turbo, it mustnt be in the exact same spot, but thats what is wrong with mine.
Users browsing this forum: No registered users and 73 guests
