so i brought a replacement diesel filter to service it myself. i purchased this from euro car parts
https://www.eurocarparts.com/ecp/c/Renau ... 745&000140
but it is a sealed unit and the one i can see inst a sealed unit and is made of metal, can i still replace the filter with the one i have purchased ?
Diesel Filter replacement
- Currently Drives:: 1.5 Renault megane dci 57 plate
Re: Diesel Filter replacement
Are you sure your not looking at your Air Con unit?
Not sure if you are aware, many aftermarket fuel filters tend to leak at the pipe connections causing air in the fuel line. This is quite a common thing and can be solved by using a genuine renault filter.
When i changed mine on my 1.9dci i just bought the diesel filter element for a tenner and took the one out of car opened it cleaned it and changed element instead of buying whole new plastic casing.
Users browsing this forum: No registered users and 73 guests
