Gearbox Reverse Switch - question on change ? ? ?
dean-weston
Currently Drives:: 54 Megane 2 - 1.6VVT
Postby dean-weston » Mon Sep 23, 2013 9:35 am
Hi guys, I’m about to purchase a 3pin reverse switch from GSF (cheapest I can find) as my current switch suffered a breakage when the engine fell as a result of an engine mount unscrewing its self.... bhut that’s a different story!
My question is, when I unscrew the existing switch from the gearbox, is it going to ditch the gearbox oil everywhere ? ? ?
Does anyone have any tips or suggestions, or will it be a straight forward unscrew and replace-
many thanks
steve-t
Re: Gearbox Reverse Switch - question on change ? ? ?
Postby steve-t » Mon Sep 23, 2013 2:56 pm
Do it like the little Dutch boy and stick your finger in the hole then using a cloth wipe round quick swap over to put the new switch in.
Steve
dean-weston
Postby dean-weston » Tue Sep 24, 2013 7:54 am
stick your finger in the hole....... works for me! :D
This kind of was my plan all along, but just wanted to check if there was a more "adéquat" method
thanks you
hardcore
Currently Drives:: RENAULT MEGANE DYNAMIQUE 1.5 DCI
Postby hardcore » Fri Sep 27, 2013 8:59 pm
There will be a good bit of oil comes out so act as quick as you can , I done my scenic reverse switch 2 weeks ago and when I took the switch out it was like taking a drain plug out , get a drip tray .
tomalamix
Postby tomalamix » Fri Sep 27, 2013 10:13 pm
watch out the qty of the "drip" because the total oil qty is 2L.
Users browsing this forum: Google [Bot] and 37 guests
