Greetings
I'd like to know how to connect the hoses that goes around vacuum, vacuum sensor, turbo actuator and solenoid valve. I had mine disconnected and now I have no idea which goes where.
Anyone with pics, sketches or details of how they are connected will gladly appreciate.
How to connect vacuum sensor, solenoid valve and actuator hoses
- Currently Drives:: Megane II, 1.9cdi
5door Renault Megane II, 6 speed manual, 2004 model, 1.9dci F9A Engine, 185 000KM.
- Currently Drives:: Megane II 2005 1.5DCi 80
Re: How to connect vacuum sensor, solenoid valve and actuator hoses
Hi, in my 1.5 dci the actuator rod connects to the turbo flap using 2 10mm nuts, then it has a thinnish tube with a small metal ring on the end connecting to a bowl shaped thingy that is on an air pipe that goes from airbox to the turbo intake. And the vacuum sensor connector is on the same harness as the EGR wires and it clips on a pipe that comes from the intercooler to the EGR air intake. Hope this helps in some way, sorry, no 1.9 for reference
Thank you ad0mas, I'll try it later today and let you know how it goes. Much appreciated mate.
Users browsing this forum: Bing [Bot], Google [Bot] and 106 guests
