Abs light has come on I cant be arsed getting under car again until weather dries & warms up a bit but MOT is due soon, I was thinking of cutting abs light wire behind dash and connecting into say oil light so it will come on with ignition and off when started so pass MOT does anyone have wiring diagram so I can find out which wire goes to which light.
TIA Alan
Abs light
- q292u
- Global moderator
Re: Abs light
Rather than spend time kludging the dash lights, why not just fix the ABS sensor?
My ABS light started coming on after the (backstreet) garage messed with the brakes. Got it fixed, then it kept coming on intermittently. And then it stopped. I expect fun and games at the MOT..
- q292u
- Global moderator
Re: Abs light
There's a manual somewhere on this site, probably has wiring diagrams..
Re: Abs light
Can anyone please point me in the direction of said wiring diagram
Re: Abs light
Hi my ABS lights kept coming on i just sprayed the sensors at the wheel with WD40 and it was fixed. I jacked up the car spun the wheel while spraying...better than destroying the dashboard...
Re: Abs light
As I said don't fancy trying to get under car on drive in this weather, will just have to ask 007, do I cut red or blue Mr Bond!
Re: Abs light
Still havn't got under car can someone come along with a dashboard wiring plan, please
Alan
Alan
Users browsing this forum: No registered users and 100 guests
