HI all ive just recently bought a megane 55 plate 1.9 dci130 dynamic my 1st ever french car and ive got issues with the start up as i have an injection fault with stop light on the dash
The other faults i had was airbag light with spanner(solved by replacing airbag rotory behind steering wheel) sunroof not opening up(solved by replacing rear hinges) battery light on dash(replaced aux belt and tensioner).
When i get it started with help of carb cleanera few times in the intake it starts and runs/ticks over fine but this is the only way it will start.
I havent taken the injection system apart to clean yet as ive read about 3-4 different options to solve issue,
1 being to replace the pressure switch on top of engine please help its driving me potty
I got the car cheap and the last time the car was on the road was almost 5 years ago ive sorted mostly everything i could see that needed doing apart from this issue
ps when car is running for about 10 mins then i turn the ignition on it starts no probs if i do it an hour later then im bk 2 sqaure 1
Injection fault
- Currently Drives:: megane mk2 1.9dci
