Sorry if this has been asked before.
I have a 2008 RENAULT MEGANE EXTREME DCI (86), 1461CC Diesel, 5DR, Manual and need to replace the rear brake discs.
When I have looked online I am being offered ones with or without the bearings is there an easy way to tell which it is by just taking the wheel off so I can order the correct parts.
I would assume that it would need the abs ring as the car has abs
Rear Brakes
Re: Rear Brakes
Just done mine came complete with bearings and magnetic abs rings
Re: Rear Brakes
Thanks I just want to be sure I'm ordering the right parts
Re: Rear Brakes
You need to measure the diameter of the discs, I got mine from tinternet you give them your reg and they look up part, not always foolproof, if I can find site I will let you know
Re: Rear Brakes
Was from " clickamotorpart " found on ebay £82.15 for pair
Re: Rear Brakes
Thanks for your help
Users browsing this forum: Bing [Bot] and 36 guests
