I have a Megane which is in French. I occasionally get a warning? in my LCD display between the gauges which says "MINI". I presume it means "MINImum"?
Looks like:
MINI
I o o o o _ _ I
I realise UK cars may be different. I've looked through the manual, both printed & PDF, but can't find what it refers to.
Any pointers would be appreciated.
Paul
"MINI" Occasional LCD Display Warning?
Re: "MINI" Occasional LCD Display Warning?
It's your available distance based on your remaining fuel. Below minimum, so it gives you no read out. Minimum as I understand it is 1 gallon.
Users browsing this forum: No registered users and 114 guests
