Smoke/Steam From Under Bonnet
- Chambo211
- Currently Drives:: Renault Megane 1.6 vvt Oasis Black
Hi everybody.After taking the kids to school this morning my wife came home and when she got out the car she noticed a little bit of smoke/steam? come out from the right side of the grill on the bonnet.
She has used the car a bit today but no more smoke/steam? has been seen.
Then when she went to pick the kids up from school she said she could smell a smell that didn't seem right
I know there isn't much to go on here but if anybody has any ideas it would be greatly appreciated.
Head Gasket springs to mind??
Please help guys!
Please help guys!
Renault Megane, Oasis, Black, 1.6, 16v, vvt, Panoramic Roof
- Ray
Re: Smoke/Steam From Under Bonnet
brakes? clutch?
- Chambo211
Don't think the brakes or clutch would cause steam/smoke to come from under the bonnet would it?
- Currently Drives:: Megane CC and Nissan Navara Avantura
Chambo211 wrote:Don't think the brakes or clutch would cause steam/smoke to come from under the bonnet would it?
Has the car got Air con?? is it still working?? stone could have hit condenser which is in front of the radiator and burst it, so the refrigerant will come out, loking very much like a cloud of steam. or it could have blown a seal joining onto the condenser. PUG 206s are bitchs for doing it!
You may get a funny smell as the refrigerant will contain oil and if that splattered about the engine bay and hit the manifold etc......
Either that or it could be somthing simple like rain hitting the radiator or condenser which both get hot and will turn the dropplets of rain into steam
- Chambo211
Ahhh thanks for that Andy.From what I'v heard and read it's not the head gasket (phew!)
Ill check to see if the air con is still working in the morning.
Still it's got me a little worried though as steam or smoke from under the bonnet scares me!
Is it something to ger sorted ASAP?
Will it re-appear tomorrow when I'm driving it if it's what you say?
Also is it going to cause me some major probs if I don't get it looked at ASAP?
Chambo211 wrote:Ahhh thanks for that Andy.From what I'v heard and read it's not the head gasket (phew!)
The way to check of the A/C is still working, turn the temp dial to its coldest position, and press the A/C button, if there is NO click/clunk from the engine bay ( compressor starting up) then this means the a/c system is short of or no refrigerant in the system. there is a low pressure switch that stops the A/C from starting up to protect it. If you here the click/clunk every 10 - 20 seconds or so of the compressor then its short cycling, again this means its short of refrigerant or the unit is going out on HIGH PRESSURE, A/C will only cut out on high pressure if the fan at the front of the car stops working or the system is over charge with refrigerant.
If it is the A/C and depending whats happened as to how its lost it refrigerant, if its just a blown seal then its the cost of a small rubber seal, fitting cost and a VAC out and RECHARGE of refrigerant. If the condenser has split or a stone has hit it then its the cost of a condenser,fitting labour, plus a VAC out and RECHARGE.
Car will still run fine if theres a problem with the A/C. Alot of people dont bother getting it repaire due to cost, but they soon regret it once the summer comes!!
If it has lost it refrigerant then u wont get the cloud of steam again, as once the refrigerant is gone it gone, it holds about 600 gramms of refrigerant.
hope this is of some help, if its not your A/C i dont know what it is
- nickbell69
freddymercurystwin wrote:Have you.....
checked the coolant level?
Chambo211 wrote:Is it something to ger sorted ASAP?
absolutely
- Chambo211
Just to update you on this one.
Coolant level seems fine.No more smoke/steam at all today from under bonnet.
I did notice on the front grill this morning there was some moisture on the grill and at the bottom of the bonnet.Is that something to worry about or could it be because it was foggy this morning and it was moisture from that?
Could it be a problem with the radiator?
Who knows... Keep watching the coolant level (check it on cold engine).
- Chambo211
If it's a problem with the radiator will the coolant level drop then?
Chambo211 wrote:Just to update you on this one.
Did you check to see if your air con started up ok??
IF you had a leak on your radiator your coolent level would drop and you would get the steam happening when the engine is up to temp and prob a puddle of water on the floor!!
If its none of the above and as ive said, it could have just been rain water (if it was raining that is) hitting the radiator and evaporating off creating the steam or your misses has driven through a puddle and the water has hit the radiator or exhaust and manifold etc.... and again evaporated from the hot parts its hit.
- Chambo211
Hey Andy
Checked the air con earlier.I turned the nob to the coldest setting and pressed the air con button.I heard like a clunk from the engine like it had turned on.I don't think it seamt to get any colder when I turned the air con on though?!
Coolant level looks ok to me,been and got some just in case though.The colour I got today is red,but the colour that's in is like a light browny/orange colour,is that because it's been in there a while or have I bought the wrong colour?
Appreciate your input with this Andy
Chambo211 wrote:Hey Andy
a clunk? mine dosent clunk, sounds like there's a problem there
