hi, i have a megane 1998 1.4, every time i brake or brake and turn the back lights come on as normal but so do the indicators and some times the fog lights looks like a xmas tree lol
Has any body else had this issue, i was thinking it could be a bad earth some where but no to sure where to look??
andy
Rear lights
Re: Rear lights
It will be a bad earth which needs redoing. If you look at the light connectors, you will find an earth somewhere.
Re: Rear lights
unclip the connector, get a jewellers screw driver and push the connectors together and clip back in
Re: Rear lights
My Megane has developed a similar problem.
Every time the Left/Right indicators are used the Fog warning light flashes at the same speed.
Also the rear lights dim and brighten at the same time.
If it's a faulty earth or connector where do I look (underbonnet, in boot, etc) ?
