Hi folks,
My radio has stopped working on my 2010 Megane Dynamique coupe (not tom-tom).
It won't turn on, although there is still a display on the dashboard panel. This happened once before, and I replaced the fuse (in the glovebox fusebox), which was the wrong one for the rating, and this fixed it.
This time, no such luck by simply replacing it.
I got the (independent) garage to disconnect the battery in the hope this reset something, but it's not helped. I had it back in today about another issue, and they say they'll need a specialist electrician, who's not cheap.
Anyone had this happen? Anyone got any ideas what is wrong / how to fix it?
And, how easy is it to remove the radio to disconnect it at source? I can't find the hook things online that say they fit a Mk III, only for a Mk II.
I've also had 2 burst front cv joints, of which I've replaced one drive shaft, and now need to do the other (see my other post)....I'm scunnered with this motor!
Any help much appreciated!!
Regards,
Martin
Megane III radio console not working
- Currently Drives:: Megane Mk III 1.6 Dynamique
Re: Megane III radio console not working
Having the same problem, did you get the radio fixed and how?
