Hi all got the dreaded check Airbag light.
Was driving along it came on and stayed on until I switched engine off. Then it came back on 15mins on the next drive. Left it over night and now it come on at every engine start.
So far I have searched and did the following
Check the driver and passenger loop clips and cleaned out. All look ok.
Checked the driver position switch. This is strange as 2 years ago a found a plastic runner and had no idea what it was for turns out it was the runner that pushes the switch in. So for 2 years this has been off. I have now attached it to the switch and makes no difference light still comes on.
I have read it could be the Clock spring but I don't hear any noise as I turn the wheel. Iam also not sure how to check the wiring on this.
Any help is appreciated.
Mk3 Airbag light
Re: Mk3 Airbag light
Just an update to say it came up with code B0096 Front right door side impact sensor.
So will clean the connection from the door plug and see how I get on.
