who uses on and do they work , does the new one for the 2010 megane cc onwards fit a 2006 cc
thanks for any replies
wind deflector
- Currently Drives:: Megane CC III
MG TF - Location: Bicester
Re: wind deflector
I use a wind deflector in my 2007 CC and it does make a huge difference. I bought mine from Classic Additions www.classicadditions.com it is a good fit and much cheaper than buying the Renault one! I hope this helps.
Re: wind deflector
thanks do they cut the wind down even with the windows down
Re: wind deflector
I don't know the answer to that one! It is lovely and sunny so I will try it on the way home and let you know.
Re: wind deflector
Thanks, we have had thick fog ,could not see the other side of the road
Re: wind deflector
It was nice enough to have the roof down when I left work. To start with I had the wind deflector up and the windows down, the wind deflector blocked any buffeting from behind the seats but you still get blown about by having the windows down. I then put the windows up as I usually do and it is much more pleasant!
I hope that helps!
I hope that helps!
Re: wind deflector
Thank you very much for your report, I will be on the look out for one now
Re: wind deflector
No problem, they are worth having. I got mine from Classic Additions as they do one for the Megane CC. It fits well and doesn't rattle or squeak!
Re: wind deflector
Your car is a huge investment. You, therefore, have to put in some work and money into protecting it and ensuring that it can serve you for the most extended period. Excellent maintenance and care are equivalent to a more extended serving vehicle, and while there is a lot you can do to keep your car safe, the first and most crucial step is protecting it from the day to day harsh elements. i forund a website here you can chose best best indoor car cover, Thanks!
