Seems to be coming from somewhere on passenger side of car (like a half empty bottle of water sloshing to end of bottle).
Have felt carpets but all seem dry.
Very little condenstation in car.
Have took grommets out of door but nothing seems to flow out.
Any ideas please ??
Sloshing sound !!
Re: Sloshing sound !!
Have a read hear viewtopic.php?f=2&t=12727
Agreed as above it happened on mine a couple of times after heavy rain but seems to go in an hour or so.. May try cleaning mine just for a servicing sake
Have just looked into bulkhead and can't see any standing water.
So does it stay in the tube or something ??
If the drains are blocked you will see the water , mine was about 4" deep until I poked the drains to dislodge the obstruction, with the bonnet open I removed the secureing clip and just lifted the scuttle panel up enough to get my hand in with a piece of stiff wire to prod the drain
Just poured warm water down both sides of bulkhead. Water flowed straight thru to behind wheel arch area.
So don't think blockages are my probelm.
Any other ideas ??
Any other ideas ??
Is it in the passanger door? If you open the door and swing it side to side you should hear it if it is..
