megane cc autolights
Hi, can anyone help, please. My auto lights stopped working via sensor, took plastic cover off to see what was wrong and found wires were held in with tape, these all came out with pulling cover off, there are 4 wires. I went to scrapyard for another connector for sensor but they are all 3 wires on a ribbon. Can anyone please tell me which wires go where for sensor please. Would be very grateful, thanks
Re: megane cc autolights
I had a look on Dialogys and, for my CC, it only states 'disconnect the connector' (5 in the image below). There is no mention of any separate cables, so it may be a single ribbon connector. Which model do you have?
Hi, thanks for the help, i cant open attached photo. I have an 06 cc, opened cover where sensors are and 4 coloured wires where taped into sensor plug connector, which came out when i removed tape. Went to scrapyard for a new connector and had 3ribbon cable on it. If i shove these wires, i into each slot at random to try to get sensor working and keep swapping round in necessary, will this cause any harm, thanks
Unfortunately, I can't find anything else on Dialogys at the moment. If you can advise the four digit model variant of your car, from the label inside the door (should be top left of the label), I will check again.
Thanks very much for your help, will do that tomorrow night and post reply
Hi, sorry for not replying earlier. There is a black, a blue, a red, and a green wire coming out from roof lining. Looks like normal household cable. Light sensor did work before, one of these must have come loose. Can i try putting them in each connection one at a time at random to see if i can get my auto lights and wipers back, or will it blow something if i do. Thanks
Forgot to add, on connector that should have been on, there is a ribbon cable with three wires in, are these 1 for lights, 1 for wipers, and is remaining one power, thanks
Can anyone help or advise please,am getting pretty desperate, thank you
