Hi guys,
Here comes another weird window post.
My d/s panel stopped raing the glass up and down upon pressing. I changed the switch for a brand new one, no more issues - for 2 weeks...then it failed again, I took the panel out and it only works with the panel laying on it's side!!??
A break in the wiring loom?
Also my passenger side switch works, although it only opens my driver side window. WTF?
Has anyone encountered this madness?
Cheers,
Mack
Weird windows
Re: Weird windows
Yeah, that sounds like a broken wire in the loom going to the D/S switch, or it could be a loose connector in the multi plug that goes into the switch.
If one switch isn't working correctly if often affects the others so that could be the reason for the funny happenings on the P/S.
Fix the D/S first then see what happens at the P/S.
Cheers.
Cheers.
Re: Weird windows
Thank you joe12
Re: Weird windows
Let us know how you get on
Cheers.
Cheers.
