I bought one off e-bay and it didnt work. I got it replaced and still didnt work.
I bought a third one and still no joy.
Does this work for later models? Or am I just unlucky?
Can anyone forward a link where I can get one which might actually work.
OBD II ELM 327 for megane 2007
Re: OBD II ELM 327 for megane 2007
i bought a cheapo one £12 works great for mine my car is 06 what are you using to run the app get torque and try that
https://www.ebay.co.uk/itm/Mini-ELM327-I ... 2a28fe1019
this is the one i bought and all works as should with torque pro on my nexus 7
https://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0966415946
I feel a bit silly now.
It seems if you have a key card the card has to be in the slot first and then it works.
- Currently Drives:: Megane II (LM1S)
hi
this is my first post in this forum.
My car is Megane II saloon (LM1S).
The service warning is "on", and the engine label is missing.
I 'm very confused if the "infinite" (maybe fake) clones of ELM327 are i) working and ii) give real and correct values as the expensive readers.
The chip ELM327 costs about 23$ from elm.electronics, so how the clone with: case,pcb,connectors,leds,"elm327",usb to rs232 chip costs under 20$(with shipping)?
Is anybody here compare the readings of a cheap clone to that of an expensive reader?
So for my car,
obdII uses K and L lines, true or not?
ELM323 is enough to build my reader, true or not?
The ecu keeps information about engine(I want to confirm the engine type, eg K4Jxxx), true or not?
With any ELMxxx interface, I can read and change(erase) also the parameters or warnings, true or not?
The DDT2000 v2.5 working with ELMxxx interfaces, true or not?
Finally suggest me the best (commercial) software that working with ELM323 chip.
regards
mitsos
PS if anybody here is very satisfied with a ELM327 clone, please write the ebay link of trader.
So for my car,
regards
mitsos
