Mine need changing, thought I would save a bit of cash and buy them myself and also fit them. Can anyone recomend some resonable priced pads and discs, not too expensive I have a megane 1.4 extreme. Also does anyone know if there are any guides on line on how to change them, is it difficult to do?
Changing your own break pads and discs?
DaveExtreme wrote:Ok, cheers will get one of e-bay.
Also one more question when you change your front discs do you need to change the back as well?
No. if you change one side, ie N/S you MUST change the other.
Front pads are dead easy to change, not sure about the discs. as said above get a hays manual.
- BurntCarcus
- Currently Drives:: Grand Scenic 2008 1.9Dci (130)
Have to get mine done myself, though i dont think id trust myself with something as important as brakes so ill leave it in and have reno charge me a fortune no doubt. Just out of intrest, they dont need to take the bumper off for changing disks and pads do they? Will have to take my led lights off if they do.
Back from Zafira hell....... Good to be home. Number 3 scenic bought and "im lovin it"
- BurntCarcus
IF you are going to attack it yourself but are a bit unsure,jack up both sides,remove both wheels,then you can use the `unfixed` side as a reference to check you`ve got it back together right. give yourself plenty of time to do it,then you can take your time + double check everything if you`re unsure.
you`ll feel better knowing that you`ve saved a few quid as well (just don`t let the missus know that you`ve got money left over )
- Bumpy macaroon
good tip that, plus look for torque settings and tighten bolts to that, in particular wheel bolts which you should check again later after a bit of driving
Bumpy and full of coconuts.
I did just my front pads a couple of weeks ago, £25 for the pads and an hour of my time. Very easy job for anyone who's tinkered with cars before. The pads I bought didn't come with any new mounting clips though but I just cleaned up the old ones, probably have to go to renault to get new ones. They did come with new caliper bolts though with the locking compound already applied to the threads. I shudder to think what a dealer would charge for the same job! hehe
Simon.
Simon.
