The EU has given this weird noise rating. I was wondering is it worth the paper its written on? I used to buy Michelin but got 2 punchers so had to get cheap ones a while back. Now its quite noisy to the point where I wonder is it the wheel bearing.
Is it worth buying mid range tyres for the sake of road noise or are they roughly the same as budget tyres?
Tyres vs road noise
- Stranger
- Currently Drives:: BMW X1
Re: Tyres vs road noise
I had Yokohama on my last 2 Subarus and switched to Kumho which were slightly more noisy but not as noisy as the rating would have suggested. My Skoda came with Continental fitted and I've changed to Avon no noticable difference in road noise but then I never looked to see if the ratings suggested that there would be.
I'm not a lover of ratings and such like, find some reliable user comments is the best way imo or simply go for it. As long as they have the correct speed rating, so as to satisfy your insurance, and give the grip that you require happy days.
Tyre noise is a critical factor in my purchase ...
And its worth noting some very expensive past tyres become very noisy as they wear...
I chose - C C 71 db tyres which have turned out to be perfect for a megane diesel in wet and dry.
Ok I found out something spooky. Tyres have a code of 4 numbers that refer to the week and the year the tyre was made. 2 of my tyres were made in 2013 but the other two budget ones dont actually have a date. That is rather worrying. I think its time to look for replacements.
Hi Wanda,
I hope you did not put the budgets on the rear...
Yes, tyres can be quite different in the noise they produce.
The production date stamp is sometimes located on the inside (visible from under the car).
Ok got it sorted. Turns out that after my Brands hatch stint the budget tyres became un even which is why they were so noisy.
