deano469 wrote:Do the resistors need to be actually attached to the radio controls (as per the pictures) or can they be installed in the wires that join the radio switch to the cruise selector switch? I've fitted an after market head unit so the radio controls are now redundant, I was thinking of just splicing the relevant wires together with the resistors in but unsure if it would work properly.
If this isn't possible, could you get away with just wiring the + and - to say a window rocker switch tyat i could install somewhere discreet or do you need a switch capable of using all of the functions? Any advice would be much appreciated
I dont think you could slice into the radio control as you wont know what wire is for what without a lot of tracing. As for the + and - only you could just put them on a rocker switch but you wont have the recal and cancel functions which you can live without.
