my a/c doesnt stop, even if i turn off the car it keeps going and eats upp all the electricity. Is there anybody out there that has the same problem or even better, the solution?
Jack
air con problem
Re: air con problem
jackyKK wrote:my a/c doesnt stop, even if i turn off the car it keeps going and eats upp all the electricity. Is there anybody out there that has the same problem or even better, the solution?
Jack
You'll have to supply a more information. The air conditioning system is driven by the engine via a belt to the compressor. Do you mean the ventilation fan stays on, or some other electrical system?
Re: air con problem
the ventilation fan stays on, at full speed. no matter which way you set it on 0 or 4 doesn't matter.
Re: air con problem
It does this when you remove the keycard and lock the car?
Does the headlamp adjustment angle position work?
Re: air con problem
it's a Renault Megane Scenic 1999, am I maybe at the wrong forum?
- Currently Drives:: Megane II 1.5 dci 86 3 door
Re: air con problem
Does it stay on if you turn the enginenoff then press the stop/start button again?
- Stranger
- Currently Drives:: BMW X1
Re: air con problem
Gumby6371 wrote:Does it stay on if you turn the engine off then press the stop/start button again?
This is a very old thread and I know that 1 of the contributors isn't a member here any longer, if you're after a solution for a similar problem you'll be as well starting a new thread
Re: air con problem
jackyKK wrote:the ventilation fan stays on, at full speed. no matter which way you set it on 0 or 4 doesn't matter.
It is really good to know about it. I was afraid of some points here about fan speed but now i am clear.
