How to retrofit cruise control, step by step..
Postby joeishmather » Sat Mar 19, 2011 12:49 pm
Parts required:
* 82 00 079 020 - Surround switch (£7.42 from renault)
* 82 00 193 673 - Blank switch (Plug- £2.70 from renault)
* 82 00 107 841 - CC/SL switch (£15.75 from renault)
Optionally not needed if you use another four push-buttons for controlling CC
* 82 00 103 769 - car radio remote control (I bought a used on of these off ebay)
And from a electronics store, maplins-expensive, so preferably other..
*900ohm, 270ohm and 100ohm resistors (16p)
*half a meter of speaker wire (15p)
*solder and soldering iron (i alredy had these, i have a gas soldering iron as i find it easier in a car as you dont need extension cables, these are around £20)
From a diy store, for fixing the control in place, glue and optionally black silicone sealant.
And that's all you need.
Once you have all these parts your ready to go!
How to
Step one: You should swap the new parts from renault with the old ones, this is simple, like lego...lol just literally swap the cover and add the switch and blank switch and plug the new switch in..
Image-this isnt my photo but it shows what to do, but like ive said its like lego, youll see what to do when you remove the old and have the new there to compare..
Step two: Now I prepared the control, I chose to not modify the sterio control and so have function of increase speed, decrease speed and recall,its fine as you can cancel the cc by depressing clutch or brake..
Below are pictures, and diagram.
(Taken from Kmarty, thanks)
Modry = Blue
Zeleny = Green
Cerveny = Red
Hnedy = Brown
On the bottom of that picture are colors of wires in connector under steer (but they can be swapped):
Ruzovy = Pink
Hnedy = Brown
Its very simple,
1,you solder the resistors to the control as shown,
2,solder the other ends of the resistors together and solder these to one part of the speaker wire
3,solder the other part of the speaker wire to the control as shown,
These are my photos..ImageImageImage
This leaves the other end of the speaker wire free and untouched.
Step three: The next step is to remove cover from around the steering wheel, there are 3 screws and then another 2 screws..
please see picture.
Step four: Now you find the two circled wires and carefully skim away some of the coating to reveal the copper, now the until now untouched end of the speaker wire. solder one part of the speaker wire to one of the wires and the other part to the other,
Please see photo.
Thats it, now the cc should function :-)
Step five:the next step is to cut a slot in the steering wheel cover to allow fitting of control, see photo
Now in mine I have glued the control in place and filled the gaps with silicone sealant.
Job done,
Im also getting some transfers printed so I can label the control correctly as cruise control as I removed the print referring to stereo control.
Hope this is helpful, let me know if you need any advice... Im here to help!
Big thank you to every one who has provided me with info to do this, wouldn't have been possible without your help!
Re: How to retrofit cruise control, step by step..
Postby davelowe » Sat Mar 19, 2011 10:42 pm
Nice work! Crap soldering though... :D
Postby joeishmather » Sat Mar 19, 2011 10:44 pm
Lol, cheers for that.... It does the job!
Gibzy
Currently Drives:: Megane 2 1.6 16v Dynamique
Postby Gibzy » Sat Mar 26, 2011 9:30 pm
Hi Mate, good post. Can you tell me what button functions what command on the CC. ( i will be using the original stereo stalk)
Sebring Exhaust,GT valance,-45 H&R springs, 19" Konig alloys
Postby joeishmather » Sat Mar 26, 2011 10:06 pm
On mine I have the -volume as increase speed and + volume as decrease speed, as the control is upside down this means that the top button is increase speed and the one button that's on the bottom, now on top, is the recall button, to switch the cc back on..
Hope that makes sense.
Joe
wyuen1
Currently Drives:: Renault Megane
Postby wyuen1 » Mon Apr 04, 2011 8:07 pm
how do i check if i got the wiring in my car to retrofit cc? i got a 54 plate megane rush very basic car :-( . cheers
Postby joeishmather » Mon Apr 04, 2011 8:48 pm
Remove the pannel with the control for headlight level and interior dinner switch there should be a White plug behind there if there is then your sorted if not it's unlikely you can do it... Hope thy makes sense, if not just ask I'll give further advice. :-)
wyuen1
Postby wyuen1 » Mon Apr 04, 2011 9:19 pm
thanks mate, i'll check it tomorrow once i get it back from the insurance company been driving a 02 focus saloon courtesy car :banghead hope it got the wiring i do alot of motorway miles
Postby joeishmather » Mon Apr 04, 2011 9:21 pm
It's great for motorway, I do 100+ miles a day normally and my mpg has gone to an average of 62! :-)
Postby Paddy » Mon Apr 04, 2011 9:23 pm
Have a 'gold star', top notch post.
Ill sticky it.
Would you mind if I nabbed it for another forum. (full credits to the owner)
Postby joeishmather » Tue Apr 05, 2011 9:23 am
Cheers,
You can... Where are you going to put it tho, it's on Renault owners and Renault sport...
But yeah no worries.
That offer of use of ur clip still going, I still need to switch the display to recognise it's on... Probably wouldn't be able to come for a month or two tho uni work is killing me atm not even started my dissertation which has got to be in in a couple of weeks!lol
Postby Paddy » Tue Apr 05, 2011 3:48 pm
Yea no worries.
Im in Hudds for at least the next six months so no hurry.
Postby joeishmather » Tue Apr 05, 2011 3:52 pm
Cool, thats great..
edgie71
Currently Drives:: Megane 1.9 DCi Privelege
Postby edgie71 » Wed Apr 06, 2011 5:54 pm
Hi Guys . Do you have to go to Renault to get the dash display activated on them after this mod ?
Postby joeishmather » Wed Apr 06, 2011 6:03 pm
Nope you just need to go o someone/ somewhere (generally good auto electrician) with a Renault clip, or buy yourself one...
Users browsing this forum: No registered users and 67 guests
