I wanted to clean my EGR Valve on a megane but its completely different to the guide thats on here. Took some photos whilst doing it so hopefully it will be able to help someone out.
Below are the tools I used to do this. Cant recommend enough getting some gloves. First time I done this I didnt wear any and my hands were messed up for days. No amount of washing got the stuff off
Firstly remove the engine cover this should just pull off.
Below is a picture of the EGR Valve
Then unscrew 8 bolts. (Only 7 are circled as there is one under the top right hand one I couldnt get a photo of)
Unclip the fastening holding the pipe in place and pull the pipe apart
It should look something like this when done
Next unclip the clip on the side of the EGR valve. Should be done by pressing it in and pulling down
Now you should be able to remove the EGR valve by pulling it to the right and down abit like in the photo below
Now all you need to do is clean it and put it back in. Remember that it has electric in it so just use a damp cloth and a little water.
Guide to cleaning the EGR valve on a 1.9 megane
- Boomstyliemikey
- Currently Drives:: 1.9 130 , remapped, DPF removed, Panel filter, double din
Re: Guide to cleaning the EGR valve on a 1.9 megane
Nice work! One suggestion, solvents can be used to clean the valve, but as you suggested, make damned sure the electronics don't touch a drop.
Return to “FAQ / Tips & Tricks”
