Hi there,
this is my 1st post so excuse any stupid questions. I'm looking to add a double din unit to my 2003 Megane II.
I'm looking to put in something like this:
https://www.ebay.co.uk/itm/260860949403? ... 1926wt_932
I've bought removal keys and an antenna adapter.
Do I just need a fascia like this:
https://www.ebay.co.uk/itm/160346320695? ... 1423.l2649
Or the whole kit?
Any help is much appreciated.
Double Din
Re: Double Din
You'll needa kit with a cage.. If you check thru my posts you will see one where I add a double din unit to my car.. Hope that helps
Re: Double Din
searched for it mate but the search feature is playing about for me so i had no luck.
- Boomstyliemikey
- Currently Drives:: 1.9 130 , remapped, DPF removed, Panel filter, double din
Re: Double Din
I used the facia you already mentioned and this
https://www.ebay.co.uk/itm/AUTOLEADS-UNI ... 421wt_1199
can probably find it cheaper if you spend a little time on ebay
hope that helps
hope that helps
