Hi All,
Is the indicator stalk screwed into place, or is it held with clips?
Dizzwold.
Indicator Stalk
Re: Indicator Stalk
Hi All,
On further inspection, it looks like i need to remove the steering wheel to remove the indicator stalk.
Do i need an special tools to do this regarding the airbag, or can i just dissconect the battery then use screwdrivers etc to remove?
Is there an online workshop manual somewhere?
Dizzwold.
Dizzwold.
Re: Indicator Stalk
When I removed my air bag on the mk2 , I did not remove the battery but you could remove it to be safe but just make sure you have the radio code if needed.
there are some manuals on the problem section but these are related to the mk2 but would point you in the right direction regards removing the battery
Users browsing this forum: No registered users and 66 guests
