Hi all I've decided to fit an aftermarket sterio to my car I've bee on the sticky thread on what I need but a lot of the links no longer work.
I'm after the correct adapter for my aerial and from Renault to ISO I can't seem to find correct one and halfords were useless
The current sterio is a cabasse 6 disc with s green connector to it and a wire for an aerial
Aftermarket fitment please help !
Re: Aftermarket fitment please help !
That looks like just a CD player which fits under the radio....no aerial connection on it
Sorry cannot be more helpful..my car has the radio and CD player underneath it...and your first picture is exactly like the back of my CD player...the aerial connection is like any other cars aerial....yours look nothing like a radio back
Do you think the last owner kept the radio and just left the CD player in....have you looked for a aerial wire behind the CD player or what ever it is you have got...there is not any preprogrammed buttons to select stations on yours
The blue wire which I think you thought was the aerial wire goes to the interior multiplex. Cannot see how I can add a photo to show you
Just noticed the way you get that player removed is the same as the CD player the radio has the normal four small holes to remove it
After doing some further research , the cabasse 6 disc sterio uses an amp which I'm told is in the boot!, I'll have to look but this is where the wiring for the sterio is hence I can't get a Renault to ISO kit
I'll have a loot later but sounds a nightmare may just look for a direct replacement !
I know the cd changer is usually based in the boot...never saw a radio like the you have got...good luck with it..
- Currently Drives:: Megane 225
I've got the same stereo. the amp is in the boot. it's a pain to get out as the wiring is tight and not much angle Tom play with. I'm trying to fit an Aux cable in mine. if you greet it out post a pic of the back for me
