Thought i had nothing better to do than fit a new Luk dmf, clutch kit, csc, clutch master etc to my 225,last November, car is still in my garage!!
First time i refitted box slave cylinder burst during bleeding!!!second time box was off i decided to fit 'another' new clutch to rule out a bad one, after that i just can't get the car to go into gear!!(yes friction disc is right way round!)
Gear lever is just solid,if you put clutch pedal down the gear lever doesn't go forward, if you put forward pressure on lever car creeps forward.
I have reverse bled, vacuum bled and pressure bled the clutch from the reservoir, the pedal feel 'never' changes???
At the top of the pedal travel it will move about and inch and a half with slight resistance then good pedal feel suddenly all the way down!
The pedal feel through all this bleeding never differs?
With front of car jacked up and car running all gears select all the way up the box, drop car down and gear lever is rock solid! Anyone help, please!
Im in Fife in Scotland incidentally, thanks.
Can't get gear after new dmf, clutch kit etc.
- Currently Drives:: 2005 megane 225
Re: Can't get gear after new dmf, clutch kit etc.
I think you'll find it's funked pal!
