Hello all, i have been reading the forum and it had always helped me.
But now i have a problem with suspension that i cannot find a solution.
I have 2003 Megane 2 1.6 k4m. The front lower arm bushing has two different sizes. One is with inner diameter of 12mm/outer 32mm and the other one is respectively 12.2mm and 32.2mm and i cannot understand which is for my car. My current bushing has inner diameter of 12.2mm but the bolt is 12mm, so when i put it inside there is a bit of play between the bolt and the bushing. Well i doubt there is 12.2mm bolt, but why is there a difference at all?
Here is a small comparison pic from a random seller with different sizes. They say both would fit Megane 2.
Megane 2 wishbone front bushing size.
Users browsing this forum: Google [Bot] and 96 guests
