cluch change
- Currently Drives:: renault megane 2 expression 1.9cdi
cluch change
hi my renault megane 2 expression 1.9 diesel ,clutch pedel went to the floor, recovered to a garage cluth master cylinder u/s garage say it wants replacing and at the same time the flywheel and clutch must also be replaced , is this true , cost of this including parts £ 955, dont understand why flywhheel and clutch need to be replaced un less they are contaminated, any help or info much appreciated,
Re: cluch change
If it is the master cylinder that has failed there is no reason to go anywhere near the clutch as this lives at the top of the clutch pedal.
If the garage is talking about replacing the full clutch I think it may be the concentric slave cylinder (CSC) that has failed.
The CSC is fitted in place of the thrust bearing and presses the pressure plate, take a look at the video below as it explains it better than I can do with words.
https://www.youtube.com/watch?v=DOKzndo7_aQ
The gearbox has to be removed to fit a new CSC so they are probably considering the mileage the current clutch has covered and the possibility of fluid contamination so advising fitting the whole lot.
Almost all garages will want to fit a full kit as it's more or less the same labour charge and if they only fit a new CSC they won't be able to give any guarantee as it's being fitted to a worn clutch system.
Cheers.
Cheers.
Users browsing this forum: No registered users and 0 guests
